knock sensor and knock retard question
Well tonight i tried decreasing the knock attack rate and it did jack ****.. Im getting a little frustrated with the knock sensor... i even pulled 4 degrees of timing to see if it was real knock, made no difference... I just get a constant 4. Im going to try a new knock sensor next if that doesn't work than its resistor time, and if that fails... There will be some knock sensor tables zero'd out.. The one that says max retard
Originally Posted by Flyer
I get a lot of knock on tip-in PE. As soon as I hit the throttle, and it will go away that quick. I also get it sometimes on a real hard shift. I think it's false.
When I tuned wifes Tahoe it would do the same as yours, I took 1 degreee
of entire table. Its doing better.
Mabe in 10 years I'll have HPTuner mastered.
Fast86z
08-23-2015 12:35 AM
