Knocking Noise!!?!?!??!!!
PT's Slowest Truck
Originally Posted by KySilverado
I'd say it is possible for the ceramic insulator to seperate from the metal in a plug and move about. The ticking would then be spark jumping to the head.
Otherwise it will be ugly.
As far as shorting the cylinders to locate a knock, I like to use the injector connectors instead of the spark plug wires...easy to get too, not as hot (if you're removing the wire from the plug down by the header), and alot less voltage...I've heard stories about guys grabbing HEI wires and arc welding their junk to a fender!
lukn4trbl355
10-21-2015 11:19 PM
