Kooks Header Install ?'s
Old 03-03-2012, 10:41 PM
Registered User
Lgowens2's Avatar
Default Kooks Header Install ?'s
I am about to be installing the Kooks LTs with the catted Y pipe. Do the Kooks headers comes with gaskets? Also, which O2 extension harnesses are needed? I want to make sure when I go to start the install I can finish it and I'm not without the right parts. Thanks for the help.
Old 03-04-2012, 01:00 PM
907TBSS's Avatar
Sure don't have experience on your specific vehicle but Kooks does provide gaskets...
With that said. DO NOT USE them. Nothing better then your stock MLS gasket, re-use them if there not dinged up or have obvious leaks, you'll see the carbon escaping on the gasket.
Or pick up a new set of stock gaskets.
On the extensions I can't be of much help my app. didn't require them.
Give your self plenty of time to finish, Mine were somewhat tight and things had to be un-bolted,lifted,lowered all that jazz. Just one side though.
Enjoy them! Kooks makes a quality piece.
zblee
63
06-10-2023 01:25 PM
ARC
57
02-21-2022 10:54 AM
wrb002
08-31-2015 12:00 PM
zblee
08-03-2015 03:45 AM
KOOKS Headers
07-27-2015 01:43 PM
Quick Reply: Kooks Header Install ?'s
