L83 lifter failure
Hey everyone, like many others before me I recently had afm/dod lifter collapse on my 2015 Silveraydo that has 119k on it. I want to do the repair as right as possible without replacing the cam (unless necessary due to damage). So I will likely keep the afm lifters but replace them all along with VLOM filter and put a tuner on it to turn off afm/dod. I cannot find any L83 kits to keep the AFM lifters that include all gaskets, lifters, guides, etc. anyone know of any?
I would just call the places you see these kits and tell them what you are doing. They should be able to piece together your order with the parts you want.
If they won't do that you will just have to buy the parts you need separately. It's really not much that you need. Intake gaskets, new lifters, head bolts, head gaskets. You'll need new fuel lines for the injectors as they are one time use only.
One problem I may see is that there was a shortage of AFM lifters so those may be hard to get.
I was recommended the TSP stage 2 L83 cam for my truck... lifted on 35's and tow a trailer ~ once a month... with a stock converter.
If I choose to do the delete with cam, lifters, blockoffs, tuner, etc. would I need to replace the VLOM? or is it basically useless at that point?
Ok, so got off the phone with the shop and got some new info it wouldve been nice to have before. Seems they dropped the engine oil and found debris in it. I havent gotten the truck back yet to dive into it and see what is going on but maybe it wiped a lifter roller. At this point with 119k on the truck I might just be money ahead to drop another low mile engine in it.
I have read about lifter failures after turning off afm/dod with a tuner. Does that have to do with a bad or early version VLOM? or just not replacing the filter? does the VLOM only have to do with the afm/dod and not oil supply to the lifters? Sorry for novice questions, I have gobs of engine experience but nearly zero LS experience.
swathdiver (03-07-2020)
