L92 heads on my 408 LS1?
I am building a 5.7l LS1 408. Is this worth doing? Or is there to much modifiying to make it worth the swap? I'm setting the motor up at 9:1 and will be putting on a D-1SC procharger on it.
Thanks.
Thanks.
What would you suggest for a cam? I want the car to have a good lope to it so it draws attention. You don't see sandrails with a hotrod sound. I am running Mahle 4.00 pistons with a -15cc dish. I am trying to get around 9.5:1 compression.
12 Second Club
the L92's helped pilot a friends '98 z-28 with a 370ci and an 88mm turbo to a 9.13@148mph last year. running stock valves and rockers too.
+1 for the l92's
+1 for the l92's
