are the L92/l76 DBW TB and the 05 Lm7 dbw same plug COnnector?
Old 01-26-2008 | 02:52 PM
rpav's Avatar
Is the 1.0 now obsolete? Looks like the 2.0 is new and improved.
Old 01-28-2008 | 08:48 PM
DrX's Avatar
DrX
That is correct.
Old 01-28-2008 | 08:56 PM
Truckshop's Avatar
does the 2.0 need to be modified to work w/ a tbss t-body or is it plug and play?
Old 01-29-2008 | 12:42 PM
HotRodV6's Avatar
SyTy Speed Shop
Wondering this myself.
Old 01-29-2008 | 03:43 PM
DrX's Avatar
DrX
The 2.0 will only work with the car style 90mm TB. The 2.1(coming soon) will work with either.
Old 02-01-2008 | 11:36 AM
RotaryResurrection's Avatar
What options are there for putting a larger throttle body on a DBW 02 truck, with the 2 wire connector? I'd like to run a ls6 intake.
The site above mentions "a straight adaptor harness is supposedly all that is needed to make these work" however does not mention where such a harness would be obtained, or whether it has been tested to work on an actual vehicle.
Old 02-01-2008 | 11:57 AM
DrX's Avatar
DrX
The "LS6" intake is still 78mm. You might want a TBSS intake for 90mm. Contact Speartech or google "LS2 adapter harness".
Old 02-01-2008 | 04:35 PM
thank you very much for the information. Glad to see someone knowledgeable answering questions here.
Old 02-02-2008 | 12:22 AM
rpav's Avatar
Originally Posted by DrX
That is correct.
is there no longer the pink wire to connect?
Old 02-02-2008 | 09:24 AM
DrX's Avatar
DrX
That is the primary visible difference. It's plug n play.
Quick Reply: are the L92/l76 DBW TB and the 05 Lm7 dbw same plug COnnector?
