l92 top end swap write up
Old 03-01-2008, 09:20 PM
OnyxSilveradoSS's Avatar
yea, LQ4...317 same deal both the intake.
IMO ( I am going L92) the heads flow good and you also get a larger throttle body, where if you run ported stock heads you still have the 78mm TB opening.
Old 03-02-2008, 12:01 PM
06WT's Avatar
Thanks, so it looks like a 70 80 cfm pick up, very nice. Ill photo log the whole build Ill also be installing a cam with the l92/l76 top end, if your interested in pics.
Old 10-17-2009, 12:12 AM
06WT's Avatar
ok back from the dead, i have started the l92 top end and will be posting all of my pics if anyone is interested. there is a few threads on here explaining how to do the whole thing, and theres a few threads with pics but ill try to explain everything as best i can and answer any questions i can and take as many pics as i can.
Old 10-17-2009, 12:15 AM
06WT's Avatar
i will also be upgrading the clutch.
this
will be replaced with this
Old 10-17-2009, 12:17 AM
06WT's Avatar
first step remove the belt and pump
Old 10-17-2009, 12:21 AM
06WT's Avatar
then unplug all connectors on the manifold and remove it
Old 10-17-2009, 12:24 AM
06WT's Avatar
then unplug the coils and remove the vavle covers. and at this time i dropped the headers.
Old 10-17-2009, 12:32 AM
06WT's Avatar
now at this time the heads are about ready to come off. remove the rocker rails to reveal the center head bolts. once you have loosened all of the head bolts, and not forgeting the 3 bolts that attatch the alternator bracket to the driver side head, unplug the temp sensor also on the driver side near the front of the head. and finaly the coolant crossover tube, and heads can come off. now there will be a bit of coolant that comes out of the heads when you lift them off
Old 10-17-2009, 12:46 AM
06WT's Avatar
now time to start cleaning off the deck(head mating surface) i pre soaked the whole top of the block with purple power deluited in a spray bottle and let it sit while i swapped my springs out of my old heads.
and be sure to retain the head dowels(the 4 large roll pins on the outer perimeter of the deck) when cleaning the heads. they can be pulled out with a pair of needle nose pretty easily. then pull the lifter boxs(plastic trays directly above the lifters) out and stuff some rags over the lifters to prevent large debris from getting down to the vally.
Old 10-17-2009, 12:47 AM
06WT's Avatar
then wire wheel the pistons and the deck surface until its shiny and clean
Quick Reply: l92 top end swap write up
