L92 vs LS3
LSX-L92 cylinder head
• L92 style rectangle port design
• 2.165" solid stem intake, and 1.590" solid stem exhaust valves
• 15° valve angle
• 260cc “as-cast” intake ports, 80cc “as-cast” exhaust ports
• 70cc “as-cast” combustion chambers
• Uses LS3 rocker arms/LS7 bolts
LSX-LS3 cylinder head
• 2.165" hollow stem intake and 1.590" solid stem exhaust valves
• 15° valve angle
Same block
Same pushrods and rockers
Different water pump and harmonic balancer
Different front timing cover
• 15° valve angle
• 15° valve angle
Same block
• 15° valve angle
• 15° valve angle
Same block
• 15° valve angle
• 15° valve angle
Same block
