L92 won't turn by hand...help
Old 07-28-2013, 03:04 PM
chevrolade's Avatar
Default L92 won't turn by hand...help
So as I have don't many engine swap before this is a first for me
Bought a 6.2
Added ls7 lifters new oil pump and pan
Engine would spin freely with heads off in stand
I installed heads etc
Today as I go to bolt up the converter man the engine won't budge at all.
Afraid to break the flywheel or even the crank bolt
Any ideas ?
Old 07-28-2013, 03:07 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Are the spark plugs in? What are the cam specs? Have the heads been shaved? Stock pistons?
Old 07-28-2013, 03:09 PM
chevrolade's Avatar
Stock pistons stock heads cam is in but timing chain is off no spark plugs no rockers or pushrods on yet
Old 07-28-2013, 03:21 PM
10 Second Truck Club
RS/SS 4.8's Avatar
Are these motors interference motors? If so and u have the pushrods/rocker tightened down but the timing chain loose maybe a piston is caught on a valve.
Old 07-28-2013, 03:34 PM
chevrolade's Avatar
No I don't have rockers or pushrods on
One thing though 2 flywheel bolts that go to crank went in tight others went in smooth
Old 07-28-2013, 03:36 PM
Is the converter not pushed all the way back?
Old 07-28-2013, 03:50 PM
chevrolade's Avatar
Yea converter spins freely but flywheel won't budge
Old 07-28-2013, 03:54 PM
Is it a dished flexplate for a 60e? Or a flat flexplate for a 80e? The flat one needs a spacer.
Old 07-28-2013, 04:05 PM
eallanboggs's Avatar
Lack of experience can be a formula for disaster. A CARDINAL RULE: ALWAYS manually turn the crank after EVERY step is completed(This only take a minute because the rachet is already sitting right there). This is extremely important, but none of the repair manuals mention it and that includes the pro services such as Alldata and Mitchell. If you do this ONE extra step you'll save yourself a lot of headaches because you catch the problem right away instead of after a bunch of other stuff has been installed as it appears to have happened in this case. You need to turn a minimum of 720 degrees of crankshaft rotation.
Old 07-28-2013, 05:20 PM
iamkeniff's Avatar
Did you put the flex plate on the correct way?
Quick Reply: L92 won't turn by hand...help
