last exhaust question (hopefully)
ok stupid questions will be following this sentence
so im this close to finally getting my exhaust done. Pacesetters on their way. Getting Magnflow HF Cats 94606, Muffler 12568, and Tips 35163. True Dual 2.5" exhaust.
I will be installing the headers myself. Wondering what are the manifold, manifold sheild, and collector bolt sizes?
Im getting Stage 8 bolts from Thunder, is 114-8900 the correct ones to get? Should I put anti-seize on them?
Should I try and reuse the gaskets or buy some new stock ones? What type of sealant do you put on the gasket? Both sides?
I know to install driver from the top and passenger from the bottom. Also unbolt the steering shaft to help get that outta the way.
I will be driving about 30min to the exhaust shop with just headers. It shouldnt hurt anything
Anything else let me know
you can reuse your gaskets seeing your only a 2006.. the manifold bolts are 8mm yes put anti-seize on them... you dont need to take the sheild off....i didnt put any sealant on my or anything and they dont leak...
o yeah... a set of ear plugs too... that ****** is going to be LOUD!!!! hope you dont have a cop within a mile or so of you... he will hear you and pull your *** over
FlowmasterMufflers
07-17-2015 03:26 PM
FlowmasterMufflers
07-09-2015 12:23 PM
FlowmasterMufflers
07-09-2015 12:00 PM
