Leaking LSXRT
Old 07-31-2011, 11:38 AM
  #21
1994Vmax's Avatar
Originally Posted by neilownz
Could have been messed up in shipping...
How would you mess up a formed composite manifold in shipping to make the ports sit uneven on the heads? I mean I think you would notice if it was damaged physically and to cause that it would have to be a mess. Unless of course you managed to heat it and twist it. It just wasn't formed correctly in the mold by the sounds of it, or the final machining ( if they even do any) wasn't done. It's kind of important to have your port face straight and apparently FAST forgot about that one on 2 seperate intakes in this instance.
Just sounds like a really poorly made overpriced POS.
Hopefully FAST is taking responsibility and at least refunding the OP for these messes.
Old 08-03-2011, 09:35 PM
  #22
hirdlej's Avatar
What's the verdict on this one? How's COMP treating you?
Old 08-04-2011, 04:03 AM
  #23
Man Motor club
rjwz28's Avatar
x2....
Old 08-04-2011, 07:29 AM
  #24
06Sierra2's Avatar
in for updates, this thread has got me reconsidering ordering one, maybe ill just go for a tbss one...
Old 08-04-2011, 01:02 PM
  #25
PT's Slowest Truck
budhayes3's Avatar
Man this sucks, even Comp's plastic parts don't work right
Old 08-04-2011, 02:54 PM
  #26
TXsilverado's Avatar
it seems like the only products you can trust from comp here lately are their cams and their pushrods.
Old 08-04-2011, 06:19 PM
  #27
gnd111's Avatar
Originally Posted by twolow02fransen
Nah I wouldn't trust there cams either a guy over on tech lost the motor in his ls1 cause there wasn't enough PTVC cause the cam wasn't ground right
That isn't the only way that happens.
Old 08-04-2011, 07:06 PM
  #28
11 sec. Truck Mod
TIM Z's Avatar
Old 08-04-2011, 07:13 PM
  #29
skolman91's Avatar
I know maybe a yr or so ago they also had a bad batch of hardened blanks or something similar and the facing was grooving/chipping and coming off. That was one of a few reasons why i decided to not get a comp ground cam..
Just add it to the list of comps great quality record..
Old 08-04-2011, 09:03 PM
  #30
PT's Slowest Truck
budhayes3's Avatar
I've seen a few Comp cams with flat lobes, but I think that all of them were using Patriot Gold springs...maybe a spring issue or a bad combo of parts
I haven't heard of any of their pushrod failures...although I may just measure my Comp pushrod length checker to make sure that it's made right!
Quick Reply: Leaking LSXRT
