Leaking LSXRT
#42
Going by the few that have said that they would of gotten this intake including myself and wont now knowing this. I'd say they have lost out on a few sales, but i doubt that will hurt comp and their advertising much..
But if their were enough complaints, would they try to correct the problem or ignore it like they have know to do before is the question..?
#43
bgray hey buddy I just wanted to give you something to check with the intake before you give up on it. I put one of these intakes on my truck and was having about the same problem just not as bad. But I remembered when I put my injectors back in the bottom of the intake they were crazy tight to get in. So I took it back apart and sure enough it had cut 6 out of 8 lower injector o'rings. So I ended up just finding the correct size o'ring myself and fixing it. Not saying that is your problem but its something to look into....
I will get a picture tonight when im up there of how far off the straight edge is, its a good 2 mm from one end to the next.
The only Way I can see this intake fitting 100% would be to have the intake shaved so it was infact true..However Im not about to go through all that bs Im not on the hunt for EVERY SINGLE HP in my motor, its more a show queen than a driver. If in Canada Speeds shops were as common as they are in the states It wouldnt be an issue, however up here there is none worth going to (IMO) so im on my own.
ITs definetly dissapointing, however FAST customer service is evne worse than the product. Guy treated me like a ******* moron on the phone, and kept saying how my heads and motor arent proper and thats why it fits like ****. I had to speak to a higher up guy who actaully new LS based motors. The FAst fits like dick on both my 5.3 and 6.0, so its not like there was an error on my part as the 5.3 is stock heads
#44
Another intake here with the same problem, i havnt installed it yet or contacted comp about it, have had it for about a month sitting in the box after this thread came up i decided to check mine. Mine has issues on both sides on the second port back #3 & #4 are both "high", the straight egde will "teeter" sp? back and forth on that port if that makes sense. Im just gonna take it to a belt sander real quick and go on, i guess. Anyone see any problems doing that?
#47
PT's Slowest Truck
#50
PT's Slowest Truck
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
