Lets play...Name that broken part
#131
what a rush!
Originally Posted by 1SlowHoe
Just spent the last hour on the phone with Joe Vinci. After talking it all over I went with the ASP Kicker cam and thier titanium springs. He said these will work with stock pushrods and rockers. After I told him I would be shooting for 8#'s of boost on the LQ4 he said the ASP was they way to go. Should have a little chop to it and it pulls from 1900-6000. Also found out I will need a water pump gasket, Crank bolt, Valve seals, Timing cover gasket and seal.
Guess I need to go to the dealership or GMPartsDirect.com. Anybody got part numbers?
CAM SPEC:
DUR @ .050" 210*/218*
LIFT .551 / .551
OVERLAP 52*
LSA 112*
CAM SPEC:
LIFT .551 / .551
OVERLAP 52*
LSA 112*
what are the .006 specs?
#132
Just get the Scoggin Dickey Cam Replacement Gasket Kit here. Should have everything you need.
Interesting cam choice....with a 112 LSA you should have all the lope you'd ever want.
You sure you need $300 springs on a cam with .550 lift? LS6 springs are dirt cheap and the 918's are only $159.
FWIW, most everyone I've talked with has said replace the stock pushrods with hardened ones while you're in there.
#133
Id have to agree, better safe than sorry. With as much as you have already spent whats a little more for some security?
#134
Originally Posted by moregrip
with -10deg it should be good with the radix. and your using stock rockers?
The other specs listed are:
DUR @ .004" 272*/280*
#135
At least now you got a good excuse to replace the rockers, cause your push rods might be weak. I bet that one beats the "Shut up woman go mow the yard" line.
#136
#139
Originally Posted by fogle04
hardened pushrods only cost 90 bucks shipped from texas speed. might want to look into them. up to you though. good luck with everything
I just got off the phone with ARP and they dont make rod bolts for a 2004 LQ4 or the lady didn't know what she was talking about.
#140
talk to jason at texas speed. thats where i got mine from. he even let me have some stock valve locks and retainers. you should just tell her that is a LS1 i think thats how they got them listed
