Lets play...Name that broken part
#221
what a rush!
Originally Posted by 1SlowHoe
Does anybody (Sponsor) do a regular bore 6L with forged internals? What is a reg 6L 363ci?
#223
How much are you planning to spend?The 402/408 shortblock specials don't include a cam or heads.A Radix 403 with a 2.75" pulley will only make 7lbs of boost,so if you want to make big hp numbers with that setup you'll need a big cam and heads setup to make power at a higher rev range.That drives up the costs pretty quick.I'm currently looking at the new intercooled Whipple setup that uses a AX3300 supercharger for my 403,I'm thinking that set up will be worth about 750rwhp with a milder cam and on pump gas.
#225
I've got a cam and springs and I was going to use stock 6L heads on whatever I get. I am willing to go 3000-3500 for a new, forged short block. So far the 402's are cheaper than a regular bore forged 6L. If I can find a used LQ4/9 I will just use it and not do any more than 8#'s and a 50 shot. I decided against the 402 because of your problems feeding it with a Radix.
#226
Originally Posted by moregrip
lol, sounds like those 402's are pretty reasonable then, so you've been quoted about $3300 for a 402?
https://www.performancetrucks.net/fo...d.php?t=350908
https://www.performancetrucks.net/fo...d.php?t=350863
#227
what a rush!
#228
I was gonna find some stock 6L heads on ebay or on here. I don't want to use the heads off the 5.3. I will of course use every other part
These seem a little overpriced but more will come available....
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
#229
what a rush!
how about this? everything is there for ya:
http://www.sdpc2000.com/catalog/123/...-C-K-G-LQ4.htm
