Lets play...Name that broken part
#451
Originally Posted by BlownChevy
LMAO I looked that that earlier and it just did not look right....Guess the daily tech calls are getting to me
I THINK you will have a problem with the way your water pump flows from the looks of the belt....I am all screwed up just looking at it
Nope water pump turns the same way either way (oppsite the crank)
#456
Originally Posted by 1SlowHoe
Hmmm. I'll have to look at that. I never had any slipping or any other issues the way it is in the pic. Whats the difference?
#457
Wow, this thread could be it's own site! When you originally posted I couldn't view the video at the time, and I guess I just never came back to check it out....did you ever post what the broken part was?? #7 piston? pics?
Today we got the 5.3 out and swapped the accessories over to the 6.0. Broke an exhaust manifold bolt, so those are still off. Got the 6.0 all done. Oil pan cleaned and replaced filter, pinned the crank, installed the push rods/rockers etc. All ready to go. See the pics, #7 Piston had issues.
Got the 5.3 out.....Man there's a lot of crap to unhook....
#7 Cylinder was the culprit......
The cylinder wall was still clean.....
Temporarily installed a VTECH but it sucked so I pulled it back out....
Best part was after we pulled the engine we went to PUSH the truck back in the stall, I opened the door, pulled the E-brake and the fat bitch started to roll backwards faster than the 3 of us could push it forwards and the drivers door caught the garage door rail Sweet huh? Guess I'm stopping at the body shop after the build....(insert mad smiley here)
Be back on it tomorrow. Doubt it will be done by the end of the day though....
