Let's talk water to air intercoolers!
Old 09-05-2004, 06:31 PM
  #21
single digit dreamer
parish8's Avatar
now this is a heat exchanger
Old 09-05-2004, 06:46 PM
  #22
MacADaYear's Avatar
How is that working out for your system?
Old 09-05-2004, 07:03 PM
  #23
vanillagorilla's Avatar
Is that another radiator? I don't think it gets any better than that.
On the alcohol note: I don't think it work as good as water, because no other liquid can absorb heat as good as water. Why not try purging nitrous onto the heat exchanger. Air to air guys do that. I've always thought that usuing liquid nitrogen or dry ice would kick ***. You could poor or mist a little liquid nitrogen onto the heat exchanger in staging. It might work, who knows?
Old 09-05-2004, 07:08 PM
  #24
parish8's Avatar
that is the original 5.3 radiator.
it's not as great as i had hoped. at the track my temps are about the same. siting in the staging lanes just puts heat into everything. the best thing is when driving on the street it recovers almost instantly.
Old 09-05-2004, 07:14 PM
  #25
retsell's Avatar
Here is mine:
Old 09-05-2004, 07:19 PM
  #26
Here is some part #'s for you guys.
The pump is a universal anco part # 65-01. Cost at my Oreilly's is $13.69+tax
The Misters are "Orbit" Dripmasters with a 1/4" barb, 10-32 MT connection(whatever that means)
Model # 61032D that flow 0-8gph@25psi. They are adjustable, and their adjustment **** is yellow. They can be found in the gardening section @ Wal-mart, and they cost about $2
As far as using a heater core as an extra in-line heat exchanger, I found what might be the perfect one. it is 9"tall and 8"wide, about 1" thick. The hose inlet/outlet are both 3/4" and it already has 2 mounting tabs on the bottom. Cost is $34.99 and here is some part #'s for different brands : NAPA - 3336, Ready-aire(Oreilly's) - 398214, 4seasons - 94480, Murray - 279163, Stant - 90214. Those are the same heater core with a bunch of different brands.
Let me know if you need anything else
Aaron
Old 09-05-2004, 10:23 PM
  #27
Did you guys take out your AC condensor coils to make those radiators fit there? I don't see how there'd be room?
Old 09-05-2004, 10:46 PM
  #28
parish8's Avatar
i pulledmine but there is room for a prety good sized radiator up there without taking it out. i can still see retsell's ac back behind that radiator.
here is what i had in there before i put the 5.3 radiator in there. this is a radiator from a dodge daytona. got it from the junk yard for $35. it fit with the ac in there.
Texas5.3_1251
03-05-2016 08:10 PM
GMCtrk
01-27-2016 06:47 PM
SlvrSierra4.8
10-01-2015 09:39 PM
mr03silverado
09-02-2015 11:43 PM
Quick Reply: Let's talk water to air intercoolers!
