lifter tool question?
ok, so ive searched and read alot of threads. 1st question is does anyone still make the lifter tool, cause i cant find one. 2nd is ive read you can use a wooden dowl or metal rod, but ive read use 1/4, 5/16, and 3/8, so which one do i need, and does it really work cause a couple threads says it doesn't. 3rd I've read alot of people use pen magnets, if i go this route do they have to be a certain size or will any run of the mill magnet work? Thanks in advance guys.
EDIT-sorry if in wrong section
5/16 wooden dowels... get 2' rods you will have to cut them down a bit because they his the a/c... i used this method and it worked just fine
-set the pushrods in there bores and watch them come up. make sure all stay up
-i tried the pen magnet on one of the lifters and couldn't get the damn thing out it took some fine wiggling to get it out
silverstreak07
06-28-2016 06:29 PM
