First thing I would do is pull the valve covers and inspect. You can run the engine with them off also. Sounds like valvetrain to me. Poss wiped out lifter and cam. Ive seen that twice at the dealer.
pulled the valve cover and the rockers had a lot of play in the bearing shafts... side to side movements, and up and down only a couple rockers had that... spark plugs looked like its been running very rich...
Originally Posted by krambo
Wow. I have heard piston slap however I feel yours is a bit more serious. Also at 16 seconds (remaining...since your vid "counts down") I think I hear detonation as you rev the motor. Anyone else hear that?
i noticed it too...
Originally Posted by white lightning SS
An easy way to tell if ifs coming from the piston is pull the plug wires one at a time. that might be easier than backing off rockers to check the valve train.
what do you mean?
Originally Posted by twolow02fransen
yup im going to agree with you on that detonation i dont think its piston slap either i think its something worse kinda sounds like a loose connecting rod
when i turned the truck back on i checked it all out... the sound comes from both sides but its much louder on the bottom end.
Originally Posted by StrokerAce03
Do you not know how to properly spell "the" ? Every ******* one of your posts it is spelled incorrectly and its annoying as ****.
<3
Originally Posted by sonoma43
How long has that tune been on there?
sounds similar to a loose rocker...
its been on there at least 30 to 40k miles... never had any issues
