A little tease from ATI (8.1 kit) - marine only
First I have to say that this IS NOT available for the truck 8.1 motor I will be talking to them to see if there will be one in the future though. In the meantime we can dream or I could put one on my boat.
496 MAG HO
580 HP (3.5 psi) or 625 HP (5 psi)
496 MAG
550 HP (3.5 psi) or 590 HP (5 psi)
ATI is proud to announce the new ProCharger® Marine supercharger system for the Mercruiser® 496 Mag HO and 496 Mag motors. This ProCharger Marine system provides up to 625 reliable horsepower on pump gas with engine friendly intercooled boost. Installation is quick and straight forward, as this system requires no accessory relocation and features ATI’s exclusive internally lubricated supercharger design (no oil lines). This rugged supercharger is available with a 3-year extended warranty, and effortlessly produces industry-leading power on the 496. These systems also feature a compact intercooler specifically designed for the 496 motor. Installation is simple, with virtually no change to the engine envelope. Additionally, the 3.5 psi system is fully upgradable to the 5 psi system at any point, with the 3 year extended supercharger warranty still available.
Tom
496 MAG HO
496 MAG
Tom
Re: A little tease from ATI (8.1 kit) - marine only
Good question. I'm not to much into marine performance but I'd say the outdrive would probably have to be upgraded depending on how hard the boat is run. You can spend a ton of $ to get a little MPH on the top end so I haven't touched mine (23' Chaparral bowrider). I may have the computer reprogrammed this winter but that is probably it. I run at about 70MPH at WOT with 2 people on board. I rather be in a bigger boat at anything over 75-80 but on calm water 70 feels like 40.
Blown,
What drives are you running now? The Bravo 3X or XR might be up to the task of the power output of the Procharged mill. Imco Marine makes a beefed outdrive called the Xtreme. They are a good unit from what I heard from a firend of mine. Drive showers are good too!
Banned
hehe, my drive is a short shaft Champ Mercury outboard with a #4 or #6 speed master on it. hehe, bring on your i/o boats biatches!.!.!.!.!.!
Banned
dude, if you've never heard a Champ, or S2000 outboard you've never lived. they sound so different than other OUTs, they are about the same as a big cammed LS1....as far as coolness i mean...
2003, 496, 81, computer, engines, forums, ho, kit, kits, marine, mercruiser, performance, procharger, regard, reprogram, supercharger
