Long Tube Noise
Old 05-19-2011 | 07:40 PM
Chevy_King1500's Avatar
Default Long Tube Noise
hey guys I have a set of LPP long tubes for my 5.3 they are really noisy (like raspy when I get up next to a building and sound like a leak. is it from when they collect together? anyway to fix this, thanks
Old 05-19-2011 | 07:50 PM
Swerve7rpm2000's Avatar
Have you checked>?
Old 05-19-2011 | 07:55 PM
it is more pronounced when the truck is cold. so maybe it is a leak. could I put exhaust wrap on it?
Old 05-19-2011 | 08:12 PM
andrew383's Avatar
traveling mod
Its just valvetrain noise.. look for the black sooty areas for leaks but i bet its not leaking
Old 05-19-2011 | 08:14 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by andrew383
Its just valvetrain noise.. look for the black sooty areas for leaks but i but its not leaking
I would prob agree it isn't a leak.. do this^.. They are alot thinner then the manifolds are inturn letting more noise out..
Old 05-19-2011 | 08:31 PM
TX Tahoe Z71's Avatar
Yep, same noise here; double and triple checked it, no leaks. It's just the headers.
Old 05-19-2011 | 08:53 PM
ok thanks for the replies, not exactly what i wanted to hear. i did figure the piping was thinner
Old 05-19-2011 | 09:01 PM
Nuclear Endless's Avatar
Just learn to love it
Old 05-19-2011 | 09:52 PM
Forcefed81's Avatar
You'll get used to it.
Old 05-20-2011 | 07:20 AM
sintered's Avatar
If the noise is a sharp ticking sound, it's a leak. Anything else is likely just primary tube noise. Like mentioned, the factory manifolds are thicker than the headers, so with the headers you hear more of a muffled, really quick whooshing sound as the exhaust gases blast through the tubes.
An easy way to find a leak is to do a seafoam treatment and crawl under there during the running period. All the smoke will quickly help you find any leaks.
Quick Reply: Long Tube Noise
