lookin for a head/cam for 4.8 5spd v8
Old 07-02-2005 | 05:07 PM
Default lookin for a head/cam for 4.8 5spd v8
will stay N/A.
lookin for a head/cam to help me get into the low 13's or better.
have 3.73 gears, just intake/dumped exhaust now. headers and head/cam are my next choices, than a new throttle body and tune.
can someone help me pick out a good head/cam combo?
thanks!
Old 07-02-2005 | 07:39 PM
ThunderZ28's Avatar
12 Second Club
cant remember the heads.. 263 or something or another
but I really like the TR 224
needs major tuning but Holy cow... does it run
Old 07-03-2005 | 03:58 AM
224/224 .563/.563 112 LSA
224/224 .563/.563 114 LSA
both say
1700-6600 RPM Power Band. Excellent mid-range & high RPM power. Requires computer tuning on automatic transmission cars. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
i will still get it tuned but i have a 5spd...will that make a difference?
im sticking with the 4.8. my friends brother owns a customization shop. going to talk to him about a custom turbo setup...so my 'cam' choice might change depending on this conversation. but it won't be a full blown crazy turbo setup....as i would like to stick with the 5spd transmission...
Old 07-03-2005 | 07:48 AM
one03sierra's Avatar
Formerly one92rs
Talking
go with the 114 if you want it to idle. also look at this info.
https://www.performancetrucks.net/fo...d.php?t=235563
Old 07-03-2005 | 04:10 PM
it doesnt list the 114 LSA on there, only the 112
224/224 .563/.563 112 So-So Noticeable Required 2500-3000 918/921
thanks guys.
Old 07-03-2005 | 07:42 PM
Scrapin'4.8's Avatar
I also have a 4.8 5-spd and i'm just wondering if you've run it at the track yet. I've only ran mine in the 8th, there's not a quarter mile track close to home. But w/an intake and exhaust and a very badly slipping clutch, my truck pulled a 10.1 at 70MPH. I have the stock 3.42's. I also just put a fiberglass rollpan and hood on my truck, think i lightened the truck up about 200lbs by removing the bumper, reese, spare tire, factory steel hood. I'm figuring w/a good clutch i should be able to pull a high 9 at least.
Old 07-03-2005 | 07:48 PM
ThunderZ28's Avatar
12 Second Club
yes you can get the 224 on a 114..
and it is much easier to tune than the 112..
just depends on how much time you are willing to invest into it..
Old 07-04-2005 | 02:20 AM
no track time yet, been wanting to go.
i got 3.73's, just intake/exhaust. some ppl here said i could hit mid 15's or better.
i know ill be doin a 4hi launch though doin a little practice with hit, revving to redline letting it drop to 4-4.5k and doing a 'fast slip' of the clutch.
Old 07-04-2005 | 07:45 AM
Sport Side's Avatar
Yuck, a TR224 114 in a 4.8L
How about this single pattern profile: 218/218 111
It has the same amount of overlap @ .05 specs and 3* less @ .006 specs so, idle qualities will be slightly better.
For the TR224 112, we could do the same thing. Except we'd tigthen the LSA even more. 218/218 109. Same overlap @ .05 specs and 3* less @ .006 specs.
BTW, on both profiles the intake centerline is installed straight up to make the operating ranges similar to the TR224 camshafts.
Old 07-04-2005 | 01:54 PM
02sierraz71_5.3's Avatar
Originally Posted by Rook
will stay N/A.
thanks!
If you need a set of cores Ive got some perfectly good factory heads fully assembled
