Looking for 6.0 Power to Tow
Old 10-11-2004 | 02:25 PM
Roarinbear's Avatar
Default Looking for 6.0 Power to Tow
Looking to get more power (torq) out of my 02 2500HD 6.0 w/410's for towing 9500 lbs. Would I get noticable improvements, adding a K&N filter, with Magnaflow cat. back exhaust? Would I need elec. mods? Any advise without getting into the engine would be greatly appreciated.
Old 10-11-2004 | 02:33 PM
the biggest thing I can tell you and you wont have to get into the engine is get a radix supercharger. the air filter and exhaust will help a little but it really wont be noticable. what size tires are you running?
Old 10-11-2004 | 02:48 PM
Roarinbear's Avatar
$5000.00!!!! Stock tires
Old 10-11-2004 | 02:53 PM
JERRY2500's Avatar
14 Second Truck Club
One word STS, Check my Dyno sheet in sig.
Old 10-11-2004 | 03:00 PM
agreed with Jerry, or move to a 4.56 gear, you really need some sort of force induction to really ge tthat thing to handle pulling well.
Old 10-11-2004 | 05:17 PM
Roarinbear's Avatar
Thanks! Nice set up. But I'm looking at the most for the minimum.
Old 10-11-2004 | 06:02 PM
snoman's Avatar
You will by far get your most bang for your buck with deeper gears (4.56's) and then maybe a tune too. The deeper gears will put engine better into its power range when towing and will make more difference with a 9500lb trailer than anything else short of a supercharger. There is no tune that is a "silver bullet" for your problem. Sorry.
Old 10-12-2004 | 06:37 AM
JERRY2500's Avatar
The STS will give you more HP and TQ plus better fuel Mpg's. I've gain 2 mpg's city and highway and 3.5 mpgs towing. I still can't believe it. The campers 8500lbs dry and proubly 9500lbs+ loaded. I pull it 70 mph and it never get out of OD going up bridges and hills.
Old 10-12-2004 | 06:50 AM
zippy's Avatar
some type of a cold air intake, exhaust and get it programmed. the stock program on that 6.0 is pretty week. there is alot of improvement to be had there.
Old 10-12-2004 | 07:05 AM
snoman's Avatar
I seriously doubt this. (and I am not a diesel freak) They would have to be real gentle hills with a tail wind with that weight and 4.10's with a 6.0. The 6.0 is a good engine but it does not have that much beans towing in OD.
Quick Reply: Looking for 6.0 Power to Tow
