looking for a cam for my 6.0L...
#21
9 Second Club
Im confused, you wanted mileage, now you want a chunky cam and going with a verter. I just dont think that a cam above 220 is going to work best with only a 2600 converter, and it definetely isnt going to get any better mileage with any cam or converter you go with. If you want performance that 6.0l would love a mid upper 220's cam but that converter is too small for a big cam for max performance.
#23
Intake Duration: 218 Degrees at .050" Tappet Lift.
Intake Lift: .595" with 1.7 rockers.
Exhaust Duration 226 Degrees at .050" Tappet Lift
Exhaust Lift .598" with 1.7 rockers.
113 Degree LSA
www(dot)engpwrsys(dot)com
113 Degree LSA
#24
Location: Where our street cars are faster than your racecars..Mississippi
so i bought a stall this morning and going to get a cam and install 4.10's ASAP... already have LT's and ORY ,cold air intake, electric fans, and a tune.....
#27
#28
plan on it... i am going to the 4.10's 1st. but then i will most likely do the stall and cam at the same time
#30
I have a custom Ground 216/224 .551 .551 on a 110lsa and it has a bad *** idle. It is not that bad to tune either. The lower the LSA the sooner the power will come in, I love the low end with this cam...and I get alot of looks when I pull in anywhere with the wicked Idle.
