Looking at getting LS1 Long Block, help?
I would have bought it for that too, if I had the money at the time. I have seen them go around here for the same price.
For an off the shelf cam a 220 or 224 like stated would be good. Or a custom 22x/22x like a 222/22x, 220/22x, etc..
I like ls1 motors, kinda glad you did that instead of going to the 6.0 like 95% of the guys.
I've looked into the 6.0 route, around here you can't get one with less than 150,000 miles without spending $1200-1500.
I don't know if I want to use the stock heads and mill them a hair for a bit of a compression boost. The 243's on my 5.3 are 60cc chambers, but I think that'll be too much compression, either I'll mill the 241's, or swap them out with the 243's and run thicker gaskets to offset the smaller chambers.
13 Second Truck Club
60cc head on a ls1 is 11.27 to 1 with stock head gaskets
Dont be scared people run 5.3 heads all the time on ls1 motors.
yours vs stock 61.15cc 5.3 heads is only a small gain in compression
or you could run a thick gasket or -4cc dish pistons to lower compression.
-4cc dish piston would be 10.7 to 1
I guess even running around 11.25 CR... the cam will bleed some off too. I was just concerned running such a high CR if it starts to use oil. This is a DD truck. I think when I get the motor I'll run it up to the machine shop, have them put a fresh crosshatch in it, put the rotating assembly together, and new bearings.
54-418-11 - XFI RPM Hydraulic Roller Camshafts
I think this cam with 1.8 rockers is close to what I'm looking for. I'm on the fence about getting a Pat G cam. Not because I don't think he knows his stuff, but just because of how busy he is and the wait time.
The 222/226 is an EPS lobe isn't it?
Nevermind... Found it. I'm thinking about going with beehive springs since this is a DD, or am I better off with getting a set of duals?
