Looking at headers what do you guys recommend...
Old 05-22-2013, 10:18 AM
Colyn.'s Avatar
Well it looks like I will either get the 1-3/4" Pacesetter ceramic or go all out and get the 1-7/8" TSP stainless ones....
Old 05-22-2013, 10:27 AM
blackseven's Avatar
TSP is a good company. I also understand they recently redesigned their Y pipe to fit better as well.
Old 05-22-2013, 11:49 AM
Alan6_0's Avatar
calspeed performance has 1 7/8 stainless for $399, i had them on my vortec max and never had a problem with them.
Old 05-22-2013, 12:03 PM
Colyn.'s Avatar
Well looks like the TSP stainless are around $500ish and the Pacesetter Ceramic 1-3/4" were about $409ish... I don't need a Y pipe or Cats or any of that mess, but a 3" to 2.5" connector would be nice....
Give me pros/cons on TSP, Pacesetter, CalSpeed....
Why is ceramic coating looked at being worse than stainless, here I thought the ceramic was the way to go... Im so very confused on which company I should go with...
This is what my exhaust sounds like now....
https://www.youtube.com/watch?v=zHVeM61k8nY
Old 05-23-2013, 07:07 AM
blackseven's Avatar
Stainless steel is more corrosion resistant than Mild steel. Coatings can flash off (especially if you're not re-tuned properly). Running too rich/lean will cause the coatings to get hotter then what they're rated for. Stainless will technically last longer, but that's not to say you won't get a good life out of the pacesetters if you're properly tuned. The Ceramic coated headers are Mild Steel, which will oxidize quickly if exposed to the elements.
Old 06-01-2013, 01:57 PM
craigsix's Avatar
i like my kooks headers tough expensive.
Old 06-01-2013, 02:12 PM
damianldaigle's Avatar
I'd go with the 1 3/4" being these are for a truck the extra torque is always welcome. You'll never miss the few horses you could gain with the 1 7/8", I personally wouldn't suggest the 1 3/4" for any truck application under @408ci. Once you get into the larger cubic inches the 1 7/8" may be necessary.
As for as the coatings or S.S. I'd recommend going Stainless. They'll last longer, If this was a car I'd go with ceramic coating to reduce under hood temps. Trucks have plenty of room for airflow making underhood temps not as critical
BKnBLK05
12-28-2015 08:52 PM
Go5.3tt06
09-12-2015 09:29 AM
fillpot
07-26-2015 07:21 PM
lxcoupe
07-21-2015 02:12 AM
GM-only
07-19-2015 10:48 PM
Quick Reply: Looking at headers what do you guys recommend...
