Looks like I lost #7 piston
#164
DONT WORRY BRO.. DEPENDING ON THE COMPANY... IT WONT TAKE THAT LONG... ITLL ALL BE COOL, AND YOU WILL BE UP AND RUNNING AGAIN SOON
#169
blownerator
Becasue you can operate your power adder in its efficency range......have less problems with the motor, and make BETTER HP. I have discussed this with Rex in detail, I am sure he will comment on it.
As for dipshits comment, I will take 600 RWHP and 18mpg any day of the week
#170
Finding a good 6.0L block is an issue. Rex has one, but it's the older style that takes the different length head bolts, so I'd have to get new studs, which adds to the price. Also just talked to him about running a 5.3 block bored to 5.7 specs and running my 4" crank to make a 383 and he thinks I'd be better off working off the 6.0L block. Cost of boring/decking/line honing a new block would likely offset the savings from running an off the shelf LS1 piston. I really think that sticking with the block I have is probably going to be the best deal.
Brian, I did talk to Rex and he thinks that going another .010 over on my current block is going to net the best results.
