Looks like I lost #7 piston
Old 05-30-2008, 09:32 AM
  #181
TurboGibbs's Avatar
Those pistons you have are an inboard forging. They use a 2.5" ish wrist pin instead of the 2.950" that the standards use that i've seen. The first set i'd used was from Diamond in Curtd's 383. The spec sheet said a MINIMUM of .0075" piston to wall clearance. I was thoroughly confused and call their tech department and they said the inboard forgings grow more and need the more clearence. Still in disbelief I had the machine shop set the clearence to .0075-.0080". I guess it was ok cause Curtis's engine has very little piston slap on a cold start and is still taking ~15 psi boost. I don't think it burns oil either. Maybe he'll confirm that.
Old 05-30-2008, 09:42 AM
  #182
High on diesel fumes
thunder550's Avatar
Hmmm....I'll check with Rex on the inboard forging deal.
Cause is unknown yet, but cooling issues around #7 are suspect. Didn't wash the rings, no signs of detonation, and the #7 injector was flow tested to be about equal to the rest.
Old 05-30-2008, 09:45 AM
  #183
thunder550's Avatar
Julien, Rex and I are both talking in terms of longevity. From the beginning the plan was to build a motor that would last as long as possible. We're on the same page in that we don't want to take shortcuts. He doesn't think I'll have any issues at all taking this block to .040 over.
Old 05-31-2008, 03:15 AM
  #184
GFYS and STFU
Spoolin's Avatar
Ok...good deal then!
The anti-**** patrol will start in the morning!!
Old 05-31-2008, 05:15 AM
  #185
10 Second Truck Club
CurtD's Avatar
I have no oil burning / excessive use problems. The only noise i have comes from the triple disc converter...man it rattles.
lukn4trbl355
10-21-2015 11:19 PM
turbo6c3
10-05-2015 06:11 PM
trevorh1
09-27-2015 08:47 PM
sTNT971
09-26-2015 04:22 PM
Quick Reply: Looks like I lost #7 piston
