loss of power
loss of power
i got an 03' silverado and recently put an 80MM BBK TB on it along with a TB spacer and CAI, the problem is when i put it to the floor i get a reduced engine power at about 4500-5000 rpms and when i check the code it says throttle module input. What could be the reason behind that, some say it could be my throttle position sensor or just the TB itself, if someone could help me out i'd appreciate it. it has a 5.3 also.
is your truck stock if i were you id take the tb off we put the bbk 80mm on a 04 GTO that was stock did a before and after on the dyno and the car lost hp unless you have a blower or turbo or lots of hp, its not worth it
17,16,15,14,13,12,11 Drvr
When i first got my BBK T/B i lost a .5 in the 1/4 due to no tunning for it, also with the T/B space your blocking alot of air that you have opened up with the 80mm. One of them is going to have to go. I gained 10rwhp with the BBK after tunning for it.
took off the spacer
Superman09
09-25-2015 05:55 AM
jtphelps289
09-11-2015 06:37 PM
MA$TER_E
09-09-2015 03:14 PM
