loss of traction at 60-70 mph?
Old 02-28-2003, 07:07 AM
Seeing Red Again's Avatar
Default Re: loss of traction at 60-70 mph?
Regarding locking diffs:
The GM 10 bolt axles are basically the same layout as a Jeep Dana 35 with C-clips. There are basically 2 kinds of full blown lockers, the kind that replace the spider gears (Lock-Right, E-Z Locker) and the kind that replace the carrier (Detroit locker, ARB air lockers, Eaton electric lockers). Not to mention there are several baddass limited slip diffs out there.
All of the above can be installed by a shade tree mechanic, but the ones that replace the carrier are harder because they require shimming and the pressing on and off of bearings. The ones that replace the spiders gears (assuming you have an open diff now) are easy as hell to do, but are not nearly as strong or quiet.
For a street truck, I'd recommend a tight limited slip because of it's smooth operation.
My $.02
Old 02-28-2003, 07:29 AM
02RedWS6TA's Avatar
I don't know about your situation but I had a bone stock 1999 GMC 1500 Ext. Cab with the 5.3 and it went through 4 sets of U-joints, 1 rear, 1 transfer case, 1 snapped DS, 1 transmission, a few sets of tires here and there, and I am forgetting things but all the stuff listed happened in under 36k miles.
Old 02-28-2003, 02:33 PM
KeukaZ71's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 99FireTA:
<strong> Hey Mike, that sounds like a good idea to me. My buddy up here has a shop that I could probably use, not to mention his help!! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">sounds good rob, i'm in. i just need to locate a good LSD and company to buy it from. hey guys where is a good place to buy?
Old 02-28-2003, 03:20 PM
KeukaZ71's Avatar
i probably should go w/ LSD (posi) instead of a locker. more street friendly, and less wear on my tires
Old 02-28-2003, 05:44 PM
11 Second Club
Texas Terminator's Avatar
it's called 2nd gear fried!! <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
Old 03-01-2003, 12:27 AM
RustyD
05-23-2016 07:04 PM
Vortec350ss
01-12-2016 10:36 PM
00loudchevy
12-03-2015 05:54 PM
bearden86
26
11-15-2015 03:58 PM
Velocity1
10-02-2015 08:01 AM
Quick Reply: loss of traction at 60-70 mph?
