Low cost Meth/Alcohol injection kit?
Old 03-22-2005, 02:21 PM
CHarris's Avatar
Magnacharger does not recommend meth/alky injection. Much like a pulley change, you'd be expecting a significant impact on your warranty. I've always accepted that I do what I do with a "You break it, you bought it" mentality
Old 03-22-2005, 04:52 PM
Mr. Sandog's Avatar
Well, like you said, they don't recommend it, just like they don't recommend smaller pulleys. But smaller pulleys can be run with no damage if tuning is done. What I'm interested in is if they don't recommend meth/alky it because of warranty issues (a la a smaller pulley), or if it is because it actually causes damage (as the talk about impeller corrosiveness alludes to).
Old 03-22-2005, 05:14 PM
Just so everyone knows, SMC does sell a progressive controller now. $100. Just ordered one. The guy at smc, (scott?) said i need to scale down my PE table when using alcohol because the alcohol WILL effect my A/F ratio. He also claims it will increase my octane significantly.
Old 03-22-2005, 06:47 PM
CHarris's Avatar
I've said all I can/should. Call the tech line like I did.
Old 03-22-2005, 07:22 PM
Mr. Sandog's Avatar
I'm actually not that interested, as I will likely not be doing it. I was just curious as to if it was possible. I guess if you know, but can't/won't share, that's cool.
Old 03-22-2005, 10:00 PM
12 Second Club
O3GMC's Avatar
I'm curious as well. dcairns has a SMC kit on his Radix'd SS - http://www.silveradoss.com/forums/in...075&hl=alcohol
I can't imagine having corrosion issues with a atomized mist of alcohol or meth that probably instantly evaporates when it hits the blower....but maybe I'm wrong.
Old 03-22-2005, 11:43 PM
CHarris's Avatar
Well, I'm going to try to get a bigger heat exchanger to fit in my cramped grill area and if that doesn't work out I'll definitely be heading to an alky/meth system. I'm willing to take the risk.
5.3lSilverado
25
08-29-2016 12:48 AM
lycominghunter
08-15-2015 12:26 PM
BigEd_72455
08-08-2015 07:37 PM
fat tony157
07-16-2015 12:35 PM
zaathur151
07-06-2015 10:57 PM
Quick Reply: Low cost Meth/Alcohol injection kit?
