low-end torque+ LSx motor, is it possible?
Old 04-07-2009 | 06:16 PM
Mighty Whitey's Avatar
12 Second Club
Default low-end torque+ LSx motor, is it possible?
it's a given that the LS motors lack the low end grunt that most older small blocks seem to offer. what's it take to get some more usable "truck" power out of one of these motors?
big blocks always produce low end, and the general conception is that a stroker does too.
would a 408 with L92's and an LS6 cam run worth a f*ck for real-world, trailer pulling power? or would it be a dog down low like everything else, and run out of breath up top?
Old 04-07-2009 | 06:38 PM
NateZQ8's Avatar
Um.......ok so tell me another 320-366ci smallblock that "Stock" makes the 400 lb ft of TQ that an LS2 does
Old 04-07-2009 | 06:47 PM
00ChevyScott's Avatar
Wearin' da big hat
at 4400 RPM...
Old 04-07-2009 | 06:52 PM
joeyc125's Avatar
11 Second Truck Club
Originally Posted by 00ChevyScott
at 4400 RPM...
EXACTLY!
Old 04-07-2009 | 07:16 PM
Mr. Sandog's Avatar
If you want more power from an LSx motor, your choices are:
(1) more displacement (i.e. 400+ci)
(2) twin-screw/roots blower
(3) 3200+ RPM converter
Of course, choice number three is the easiest...you simply bypass that useless, low-RPM stuff.
Old 04-07-2009 | 07:21 PM
Mangled03gmc's Avatar
Baltimore Whore
at 4400 RPM...
Yah I was thinking that toooo.
Small split dur cam, small primarys, with some gears, blower or FI will also be a def way to achieve this, or a big CI motor, like has been said..
Old 04-07-2009 | 07:23 PM
nonnieselman's Avatar
Blower!!
6# boost and 50 Shot i made right at 480TQ at 2500rpms
Old 04-07-2009 | 07:59 PM
NateZQ8's Avatar
So your saying you would rather have a GEN1 SBC that makes 300 lb ft from 1500-4000 then falls on its **** because the head designs are HORRIBLY inefficient compared to the cathedral port LS types..........
Old 04-07-2009 | 08:04 PM
BlackGMC's Avatar
Resident Retard
10.5-11.0 CR...
Or
You can "Scott-size" your torque converter...
Old 04-07-2009 | 08:05 PM
NateZQ8's Avatar
Hey haven't checked your cam thread..........how did it go?
Quick Reply: low-end torque+ LSx motor, is it possible?
