Low, Funny Idle on stock 5.3???
#21
had same problem on my 03 silverado rmove intake tube and clean throttle body by the right cleaner make sure you dont use carb cleaner they make a throttle fuel inector safe cleaner.
#25
Ill bet it is the fuel pressure regulator because i have a 00 silverado that studdered and sometimes turned over quite a few times before starting and then i replaced that and now its fine again, my cousin had the same problem on his with even less miles.
#26
Calling up an old post ( I did use the "search" function! ) due to a similar condition on my bro's 99 Silvo.
Poor idle, sometimes dies when going into drive/reverse, OK once rolling, starts fine, SES for lean condition on both fuel banks. Checked the fuel pressure, it was about 55psi at idle, initially goes to 60 once the throttle is open but drops to 50psi under load. No fuel present in the vacuum source or in the regulator itself. BTW, does the plastic ring go before or after the o-ring? The assembly came apart and I was not sure. I have the o-ring butting up to the small filter in the fuel rail, then the plastic ring, then the regulator.
This started after he ran out of gas a few times and I found the MAF had come loose from the Volant box ( he beats on it sometimes ). Cleaned the air filter, replaced the fuel filter, used some cheap injector cleaner, etc. The Seafoam/TB cleaner sounds like a good place to start, so does the IAC and MAF clean too.
Sorry to hijack, thanks for any suggestions!
#27
Found my problem, the tube from the EGR to the manifold had broken in two and was sucking air all the time. Temp plug, idle is fine and engine runs much, much better.
#28
Help, I am having the same problem w/ my wifes Tahoe.
It is an 01 model - 5.3 w/ 75K - It does not have the cable going to the throttle body.
I changed the plugs NGK TR55 and Taylor wires
Cleaned the T.B.
So do I or do I not have and IAC that ya'll were talking about???
Where is it?
Cleaned the T.B.
Where is it?
#29
PT's Slowest Truck
Cleaned the T.B.
Where is it?
Cleaned the T.B.
Where is it?
#30
Thanks for the reply.
I'll check the fuel reg. and maf tonight.
I did the seafoam on my Camaro so I try it also this weekend.
I read something about a throttle position sensor.
Could that be the problem also - If my truck comes w/it???
