low, then no, oil pressure
Most of the posts i read regarding the subject suggested that it would be pretty useless to do so, other than just coating them with oil during assembly. And the hole inside seemed so small that I did not think oil would simply drain into them without being forced in by 40-70psi of pressure. Is it standard procedure to soak them?
I usually use a bosch filter and castrol synth. KNowing that I was going to use this oilchange as a "flush" and only run it for a couple of days, I went with walmart 20-50 oil and a fram filter (it was late, the auto parts stores were closed, and walmart only carries fram). I am gonna try to reinstall the diff and **** today even though I am working outside and it is bitterly ******* cold here today. I will run it for a day or 2 and then change back to my standard stuff. At this point the entire oil system is clean as a whistle except possibly for the radiator/oil cooler chamber.
alright now, I'm about to get really pissed.
I put it all back together and let the engine run until it warmed up, and then probably about 20 minutes more while I cleaned up my tools and such. Then I went for a drive up the road, keeping it out of overdrive so the rpms stayed between 2000-3000 to help pressurize the lifters.
With the oil warmed up I am once again seeing VERY low pressure. At idle I see 10psi steady and from idle until about 3krpm (I havent went any higher) I see steady 20psi.
I guess I'm about to order a f*&^ing oil pump and prepare to do the same job all f*&^ing over again.
