low, then no, oil pressure
#81
well, revs for sure wasn't it. It never got above 3krpm on the new cam.
cheap oil wasn't it...I run castrol 5-30 full synth. I did change oil immediately after the cam install.
The cam was a "regrind" sold by a former forum member, so it would well have had a defect. I suspected the cam was the issue the whole time, since that was the only thing not stock.
#83
yeh im withya thats y i said mic it ,i was even thinking 1 journal might have been larger than the other ,it seem that way,like somone mentioned u got a fluke aftermarket cam .that wiped out the bearing.good luck ,boy the thing you learn ha ,whats the chances.
#84
I'm not too bummed. I know a lot more about the external and internal workings of this particular truck now, and I also found a zero mile rebuilt 04 LS6 for 1500 bucks that I am getting this weekend and should have it up and running in a few days. I'll probably just get a tune and run it as-is for a while and later turbo it as originally planned with my lq4.
Anyone know what the compression ratio of an ls6 with 0.030 milled heads will be? I also wonder if the engine should use stock, or shorter pushrods. The seller, who got it secondhand, doesnt know if the pushrods are stock length or not, but thinks so.
Searching the forums for ls6 doesnt exactly yeild the most precise results.
superchomper2003
08-26-2015 09:39 AM
05GMC4.8
08-07-2015 09:55 PM
Ferocity02
07-17-2015 07:05 PM
