LQ4/9 no oil pressure !
I just built with a lot of help a .30 6.0. I'm not getting any oil to top end.
right at the oil filter there is a "oil filter bypass pressure valve", Can anyone tell me what this is for? or if it could be why i'm not getting or holding prime? there is nothing in the hole that that valve goes in. the o'ring on the oil pump has been checked and recheck so just trying to single things out before going back into the oil pan. We have also tapped the oil cooler block off and tried to prime I that way with no luck. any thoughts would be great
I just bought these, going to give the port on side of the block a boost with 4 or 5 quarts. cross your fingers for me. I hope I can get it to hook up to my garden sprayer to pump this POS full.
EAR-9919DFDERL -6AN TO 10MM X 1.5
SUM-220121 -6 TO -4 ADAPTER
SUM-220700 TWIST-TITE -4 END STRAIGHT
