Lq4 built and started!......somethings not right
Old 01-31-2020, 01:36 PM
  #111
T-RevMotorsports's Avatar
Mine did just fine, you have your arms adjusted kind of weird. I bolted mine up to two of the upper bolts and two of the side bolts to balance it a bit better
Old 01-31-2020, 01:48 PM
  #112
stroker87's Avatar
they all sag some, part of it is the position of the block the more centered it is the easier it will turn but still takes muscle, i stand the blocks up bolt the bracket to them, then put it on the stand
@willhorne22 yours does look like its has way more sag, its try to tighten up the arms at the plate side use a jack and 2x4 to take some of the weight off then tighten maybe re-position the block higher then tighten if you can
here you can see how i have the arms located on my block, looks like the same stand as yours
Old 01-31-2020, 08:16 PM
  #113
I have a gauge for that
Atomic's Avatar
Make sure yall check the welds on the joint between the plate and the tube. Friend of mine bought one and the weld missed almost completely so the engine instantly dropped when he tried to attach it. He brought it to me and I welded the **** out of it, but if it had been just a little more welded in the first place it probably wouldve failed with the engine on it instead of immediately while he still had it hooked to the picker.
Feed (02-01-2020)
Old 02-01-2020, 05:56 PM
  #114
Feed's Avatar
Or pick up an older used, made in USA engine stand off craigslist.
Old 02-03-2020, 11:57 AM
  #115
willhorne22's Avatar
Well the saga continues. New crankshaft is here, I checked my main bearing clearances and it barely even mashed the plastiguage.
Old 02-03-2020, 12:57 PM
  #116
More delays. Gotta buy .010 undersized bearings for rods and main.
Old 02-03-2020, 01:02 PM
  #117
Nick99Chevy's Avatar
Yikes, I just checked mine yesterday. Luckily they were good.
Old 02-03-2020, 01:35 PM
  #118
stroker87's Avatar
is it in spec? what that crank turned?
Old 02-03-2020, 03:59 PM
  #119
Yah the crank was turned, the shop didn't let me know before hand I'd need undersized bearings. They wrote it on the front though.
I'll see how fast summit can get them to me. Man this was an expensive mistake.
Old 02-03-2020, 08:48 PM
  #120
stroker87's Avatar
i know when i order stuff usually less then 72 hours i have it, some times next day
Quick Reply: Lq4 built and started!......somethings not right
