Lq4 built and started!......somethings not right
#111
Mine did just fine, you have your arms adjusted kind of weird. I bolted mine up to two of the upper bolts and two of the side bolts to balance it a bit better
#112
they all sag some, part of it is the position of the block the more centered it is the easier it will turn but still takes muscle, i stand the blocks up bolt the bracket to them, then put it on the stand
@willhorne22 yours does look like its has way more sag, its try to tighten up the arms at the plate side use a jack and 2x4 to take some of the weight off then tighten maybe re-position the block higher then tighten if you can
here you can see how i have the arms located on my block, looks like the same stand as yours
#113
I have a gauge for that
Make sure yall check the welds on the joint between the plate and the tube. Friend of mine bought one and the weld missed almost completely so the engine instantly dropped when he tried to attach it. He brought it to me and I welded the **** out of it, but if it had been just a little more welded in the first place it probably wouldve failed with the engine on it instead of immediately while he still had it hooked to the picker.
Feed (02-01-2020)
#119
