Lq4 built and started!......somethings not right
Old 01-24-2020, 01:36 PM
  #51
I have a gauge for that
Atomic's Avatar
The extra noise, probably sewing machine ish, is from the walls being thinner. What you are hearing is the exhaust valves slamming shut, which is accentuated with more aggressive cams and stiffer valve springs also.
Old 01-24-2020, 01:47 PM
  #52
willhorne22's Avatar
Sadly I’m not hearing anything but knock right now. The motor doesn’t start unless I give it gas and wouldn’t ever stay running without some throttle.
how can I diagnose this motor and make sure it’s ok while I wait on new exhaust.
Old 01-24-2020, 01:52 PM
  #53
Cylinder 3 and 7 are black inside banifold and 1 and 5 look brand new
Old 01-24-2020, 01:53 PM
  #54
Atomic's Avatar
That one is tough, but an easy step is pull the plugs and see what they all look like.
Fuel soaked plugs means no ignition. Perfectly clean means no fuel. Lot of backfiring is probably no air (check rockers).
Old 01-25-2020, 12:44 PM
  #55
The 6.0 didnt survive break in. The knock doesn't seem all that loud in video but its quite a bit worse in person.
I dont know what i could have done wrong and this is very sad.
I used all new bearings, checked all clearances and torqued down with arp hardware.
Old 01-25-2020, 01:44 PM
  #56
terravast4's Avatar
wow. sorry to hear this. How was oil pressure at start-up?
Old 01-25-2020, 01:51 PM
  #57
60psi or more with high pressure oil pump and I primed it before
Old 01-25-2020, 02:01 PM
  #58
Cyl
1 and 3. Same as exhaust header. Looks like I had no firing going on
Old 01-25-2020, 02:13 PM
  #59
All passenger side fired. Driver side was getting no spark on 2 cylinders. What would cause that. My coils are and injectors are the same ones that were working perfect in my 5.3 before the swap
Old 01-25-2020, 02:38 PM
  #60
terravast4's Avatar
maybe a wiring issue
Quick Reply: Lq4 built and started!......somethings not right
