Lq4 + radix....power?
How much power can a stock 6.0 LQ4 handle?
Im about to order one for my radix and wanna know if i shold try to upgrade anything?
also, what kinda numbers will i lay down with about 10lbs?
I think parish just upgraded the rod bolts in his 6.0 and it made some power.....
I'd probably stick a nice blower cam in there while it was on the stand, upgrade the springs, and maybe pin the crank for insurance.
so heres the deal....
i had planned on getting a stock 6.0, throwing the radix on it, and trying to get 10lbs out of it. but one of the guys at SMC said a 6.0 wont make 10lbs and i should throw some ls6 heads and cam in it for like 375-390rwhp
The deal is compression and displacement versus boost. A higher displacement motor will make less boost but more power with the same blower config.
The Radix has a 3.4" pulley on an LM7, and 3.3" pulley on an LQ9, and a 3.1" pulley on an LQ4...all for 5.5-6.5 lbs of boost. Does my LM7 make power than grippy's LQ4? I seriously doubt it.
I just want to make power. id love to be over 400. i had 10 lbs on my 5.3 and if i can make more power on a 6.0 with only 7 lbs...im game for it
so....stock 6.0+radix+2.75" === ??
and would the be a good setup for a while?
what a rush!
Then you'd be looking at 10-bolt rear and 4L60 issues...
calsdad
06-14-2023 11:07 PM
lxcoupe
09-29-2015 09:20 PM
