LQ4 Swap ?'s 4L60E bolt up???
Old 03-17-2009, 11:18 PM
Default LQ4 Swap ?'s 4L60E bolt up???
The truck was originally a V6. Motor blew so the guy swapped in a 5.3 out of an 02. Everything was converted to fly by wire. Now I am swapping to a 2000 LQ4. A couple questions. I tried searching and didn't find a lot of answers. I know that some people say that the 4L60E will bolt up with the removal of a spacer, but some say it won't because of a longer crank. Can someone tell me for sure before I get there. Also, since I am drive by wire now, what can I do for the throttle body? Can I use the one off my 5.3? Also, do I need to modify the harness or does someone make an adapter for the harness? Do I need to use my 5.3 intake also? A little help please. Or would it be easier to just use all of my stock stuff and go buy a harness that was taken off a newer one that had the fly by wire? Just looking for the easiest. Thanks guys
Old 03-17-2009, 11:22 PM
GMCtrk's Avatar
It wont bolt up. Get a 2001+ 6.0 OR use the 2000 engine and get a 4l80e which will bolt up
Old 03-17-2009, 11:47 PM
What about the harness issue? I really don't want to pass this motor up considering I can get it for $600.
Old 03-17-2009, 11:48 PM
GMCtrk's Avatar
Get a whole new v8 harness
Old 03-17-2009, 11:52 PM
The 6.0 comes with a harness, but it's for cable throttle. Do I need to get one that's drive by wire because that's what my 5.3 is? Also, still leaves the intake and throttle body question.
Old 03-18-2009, 12:06 AM
Converter will work fine right?
Old 03-18-2009, 12:11 AM
PT's Slowest Truck
budhayes3's Avatar
As GMCTrk mentioned, if you're hellbent on this 00 6.0, you're going to have to bolt it up to a 4L80E as it won't bolt up to a 60E. I did once read here something about removing some spacer and it will work, but everything else that I've read through the years contradicts that. The common consensus was always 99-00 LQ4=80E only. If this is the case (I'm not 100% sure anymore due to conflicting reports), then you're going to want the harness from the donor engine that will work with an 80E. If it's a complete engine, use the intake, throttle body, etc. If not, I believe that your 5.3 intake may work, (some have different vacuum fittings by the throttle body than others) and you'll just need a cable throttle body which can be had fairly cheap.
Old 03-18-2009, 12:16 AM
GMCtrk's Avatar
new gas pedal too
If I get a cable throttle body, then I will need the cable pedal and have to redo everything right? What about a harness out of a Hummer? They came with 4L60E's? Or a Denali?
Old 03-18-2009, 12:19 AM
PT's Slowest Truck
budhayes3's Avatar
I thought that GM SUV's all got drive by wire, but I could be wrong...again
Quick Reply: LQ4 Swap ?'s 4L60E bolt up???
