LQ4 Swap ?'s 4L60E bolt up???
Has anyone used their stock 4L60e and put the LQ4 in? If so, what harness did you use? Just looking for some help this way. The cheapest I found a L80e was about $500. What all would I need to change back to make it cable throttle?
So from my understanding is that if I get an 01 and up, I should be able to use my L60e, all of the accessories, and just bolt the intake and go right? That's using my harness on my 5.3 right?
PT's Slowest Truck
This is actually my basic plan when I do my 6.0LQ9 swap. My trans will have been built, and I'm going to pull my 5.3 and slap my (not yet assembled) LQ9 in it's place, at which point I will already have contacted Justin at BlackBear to tune my PCM for the 6.0, so I'll swap that PCM in and fine tune it later...
