LQ9 with 5.3 P&P heads??
8 Second Club
the camaro croud sure likes to put the 5.3 heads on their ls1's...why is that?
for the added compression, but Im pretty most of the time they go up to bigger vavles & unshroud the chamber.
I've started work on my 5.3 heads finally... I've got the bowl throats "rough cut" in to let me start porting. I will be running 2.05/1.6 stainless valves that I got on Ebay and unshrouding the chambers to work with the 6.0's larger bore. The target compression ratio will be around 10.5:1 with the reworked heads.
Banned
1 Post
i am running 5.3 heas on my 6.0 and now i am running the same heads on my 370ci i would put the bigger valves in them but yes u can run them and no the com will not be that high around 10.7.
07NBSChevy
20
07-08-2015 07:27 PM
