Lq9 L92 L76 232/236 In and running
Old 02-16-2007, 09:09 PM
  #21
Originally Posted by 04BlackSilverado
It has a lot to do with the Dinner plate sized intake valves and the superior flow of the combination of the L76 intake and L92 heads.
I love how fast it revs!!!
your trucks looking sweet these days.
Old 02-16-2007, 09:46 PM
  #22
Stampede4ever's Avatar
How much lift does the cam have, and do you have a stall? How was you able to change the injector connections?
Thanks.
Old 02-17-2007, 07:02 AM
  #23
joshluther's Avatar
The cam is a low lift cam .57x" it is just a starting point. I may go smaller or bigger depending on the way it drives..
I have a Yank TT3000 converter.
The injector connectors are the Ls2 style (EV6), you just cut off the old ones and solder the new ones on. I got them from Speartech.
Old 02-18-2007, 04:40 PM
  #24
joshluther's Avatar
I added some pictures of the accessories.
Old 02-19-2007, 06:44 AM
  #25
I have questions about your fuel rail, did you have modify it work? And any problems with it leaking?
Thanks.
Old 02-19-2007, 04:14 PM
  #26
joshluther's Avatar
You can see in the picture where the fuel line made a 90* bend toward the brake booster. I cut the bend out and used a 3/8" compression union to make it straight. i have done two like this and haven't had any problems. You can't bend it straight, tried it and it came out like ****.
Last edited by joshluther; 02-19-2007 at 06:07 PM. Reason: Because spellcheck doesn't correct bad grammar
Old 02-19-2007, 04:49 PM
  #27
One more question if you don't mind, I've heard it's possible to use the 8.1 injectors with L76 intake, and fuel rail, correct?
Thanks.
Old 02-19-2007, 06:05 PM
  #28
joshluther's Avatar
I'm not sure if it's possible. I know Ls1 injectors you need to change the
o-rings. I have 8.1 injectors and another L76 in the garage I can check tomorrow.
I don't know why you would want to do this though the complete L76 intake comes with 40lb. injectors.
Old 02-19-2007, 06:14 PM
  #29
04BlackSilverado's Avatar
Keep them little injectors away from my intake
Old 02-19-2007, 06:49 PM
  #30
ramdaspadhye's Avatar
Was that 5.3 tuned? How was your milage in it?
Quick Reply: Lq9 L92 L76 232/236 In and running
