lq9 piston and rod question
Is $200 for low mile(20-80k) lq9 pistons and rods a good deal? I want to get a lq9, but they are hard to find. but I found these pistons and rods, and a lq4 long block( for cheap), and want to build one. I would rather do this than put heads on my 5.3. just wanted to know. thanks
Rods are the same. no need for those. I would recommend new piston GM# 19178305. Check the bore like stated above before you buy anything. If boor measure 3.999-4.001 these pistons will be O.K.. If its bigger you will need aftermarket after a hone.
PT's Slowest Truck
Originally Posted by fastrt
yeah the lq9 newer rods are beefier
5.3lSilverado
25
08-29-2016 12:48 AM
