lq9 stage 3 heads on a 5.3
Banned
i know the heads will work. but will the valves clear the cylinder walls if the valves are 2.08 and 1.60 valves. ? i know the heads are WAY overkill. but im planning on running alot of nitrous ! and when i blow this motor i can use these heads on my 6.0
Those large chambers would kill your compression. Generally people want extra compression if they're running nitrous. If you destroy your engine, chances are your heads will get trashed as well.
KyleW707
07-29-2015 08:17 AM
