LQ9 + TR224 = Stock Length Pushrods???
Old 10-02-2005, 08:44 PM
LVSTOGOFST2002's Avatar
hmmm. see now i was under the understanding that stock ls6 pushrods were 7.4 while truck's were 7.375 therefore needing hte step up to 7.4 with any bigger cam due to the base circle. Are we under the concensus now that we need 7.425 pushrods for all of tr's cams. And if you buy TR 7.4" pushrods, you're actually getting 7.43" rods?
can we get another first hand measurement or experiance here? ( not doubting you 99silver5.3, just looking for more evidence )
i bought a set of comp 7.4's and now i'm wondering if when i do my cam, i need a different set.
Old 10-02-2005, 11:47 PM
PT's Slowest Truck
budhayes3's Avatar
I'm dying to know the outcome of this...seems everything I read points towards wanting to use longer (7.425) pushrods to compensate for the smaller cam base circle of most aftermarket cams, but most of the manufacturers recommend 7.4's as part of their set...when you buy a cam and spring set from Thunder, they show 7.4 pushrods in the listing...do they mean 7.425?
Comp has different lengths to choose from, but when I did my baby cam they recommended the 7.400 pushrods to me. I wonder if I would have gone with a 7.425 if I wouldn't be hearing half of the ticking and clacking that I hear in the valvetrain
Old 10-03-2005, 12:14 AM
99Silver6.0's Avatar
Oh hell no, stocks are 7.4. You do not HAVE to run the 7.425 rods. But to get valvetrain gemoetry back to near stock numbers it is a good idea to use them. Most any AM cam is .030 smaller at the base. Yes the lifters can take up that small difference in length of pushrod. But thats not really the right way to go about it. A while back after all the people talking of noisy, chattery valve train, I did some figuring. Talked to a few guys on lifter tolerances and such. IMO it is best to use a bit longer rod.
Old 10-03-2005, 12:34 AM
desTRUCKtive's Avatar
I was told that 6.0 rods are running a 7.4 length stock from the factory. Right know I am running 7.35 pusrods with the Tr224 due to the lift of the cam. But I also have shaved .030 of my heads. I will measure tommorrow and see what the exact length on the pushrods are.
Old 10-03-2005, 12:58 AM
4.8, 5.3, 5.7(LS1 & LS6), 6.0 all have 7.4" from the factory.
Old 10-03-2005, 02:39 AM
Crap, ..... can anyone else chime in on this... still wanna see more info before i sell them and get a new set!!!
Old 10-03-2005, 03:31 AM
ok, i couldn't sleep on this one so i've done some more research and have come up with a few things.
1. Stock ls1/ls6 pushrods are variant in length from 7.38-7.395 ( rumor is saying trucks are the low number due to milder cams )
2. most aftermarket cam manufacturers recommend 7.4 ( but they dont' tell you this is with their lifters )
3. running a 7.425 is within tolerance and adds a lil more lifter preload which the stock lifters like with aftermarket valvesprings, quieting valvetrain at low rpm
4. thunder racing 7.4" pushrods are actually longer, more like 7.425-7.430
so in summary, after about an hour of reading threads on ls1tech, my reasoning, depending on stock pushrod length ( variable ) is that 7.4 is correct and will work. 7.425 is within limits and/or is correct and may help quiet the valvetrain down. TR 7.4's make life easy if you like the easy way out.
if you want to do it right, get a pushrod length checker for 20 bucks, and order the right size.
Old 10-03-2005, 04:34 AM
well i got TR's 7.4's so i should be good.
ill measure em tuesday and see what comes up.
Old 10-03-2005, 09:29 AM
I dont know I will measure both of them. I am not saying you are wrong but, I heard that 4.8 and 5.3 run the 7.5 and the 6.0 7.4.
Old 10-03-2005, 10:15 AM
Who said that???
Quick Reply: LQ9 + TR224 = Stock Length Pushrods???
