LS1 or 05+ E-fans for 03 2500 HD?
Which fans should I get for my 03 HD. It has the 6.0 liter, auto trans, and the 34" radiator, 168000 miles and is bone stock. I have a lawn service and get in and out of my truck 15 to 20 times a day and usually dont drive more than 2to 5 minutes to the next yard and like to start my truck a few minutes
before we leave each yard with the AC on to cool down the interior of the truck. so what would be a better choice even though one cost more than the other. BTW It gets 100+ here in west Tx
Thanks, Charlie
Thanks, Charlie
05 fans will fit perfectly on a 34" rad. Run a cooler t-stat and make sure your fans turn on when you want. They'll do you well.
You can also wire a switch in to have your fans manually turn on/off when the motor isn't running. Will have to be wired into your harness though.
calsdad
06-14-2023 11:07 PM
FormulaZR
09-14-2015 05:23 PM
