LS1 based engine question?
Old 07-15-2004 | 07:39 PM
moregrip's Avatar
what a rush!
Default LS1 based engine question?
Are our 4.8/5.3/6.0 engines interference or non interference engines?
Old 07-15-2004 | 09:33 PM
GREGGO's Avatar
I may be the only person that does not know what your talking about.
Old 07-15-2004 | 09:56 PM
Black Blown 02's Avatar
Nope...not the only one.
Old 07-15-2004 | 10:01 PM
XLR8NSS's Avatar
Adkoonerstrator
Description of interference and non interference engines here.
http://www.familycar.com/CarCare/TimingBelt.htm
The LS1 is a vavle mangling, piston smashing, pushrod twisting interference engine AFAIK.
Old 07-15-2004 | 11:01 PM
I see! I changed the timing belt on my ford escort beater. Had to drop the engine about 6 inches to get to the crank pulley bolt. Took me 8 hours.
I'm glad our engines don't use them!
moregrip's Avatar
what a rush!
appreciated, some things never change.
hasn't chevys small block always been an interference motor?
Old 07-15-2004 | 11:30 PM
gcooper's Avatar
Thank god we dont have cheesey belts. Good ol chain.
Old 07-15-2004 | 11:48 PM
moregrip's Avatar
what a rush!
Kind of curious what replacement interval for the timing chain would be appropriate for supercharged/turbocharged/N2O applications?
In other words, what safety margin would most feel comfortable with under any of the above conditions for replacement?
Old 07-16-2004 | 09:33 AM
marc_w's Avatar
Definitely interference.
Old 07-16-2004 | 09:35 AM
marc_w's Avatar
A non-interference motor is one in that has HUGE piston to valve clearances. So huge, that with a piston at TDC, you can spin the cam two revolutions and not have any valves hit it.
It would basically be a very low compression, old design motor.
Quick Reply: LS1 based engine question?
