ls1 cam in 5.3
Old thread bump.. I have a stock 2000 ls1 cam from my dad's formula in my garage (1998 - 2000 Fbody 202/210 int/exh @ 0.05" duration 0.496" / 0.496" int/exh lift 116 LSA), which is an 11* intake and 20* exhaust bump in duration over my 5.3 stock, about .04 more lift aswell. My plans are only tuning and longtubes. I intend to keep a smooth idle and good mileage along with full towing capacity. Time spent (or "wasted") on install isn't a big concern. Mod for mod, could I expect 10 horsepower over the stock 5.3 cam? Compression and everything else is a factor, but ls1's have a nicer idle imo than the blub-blub of a truck.
Check my sig. I did the 98-99 spec. LS1 cam w/ a hair more dur. but at the same time did heads and injtrs, tuned & headers, It runs pretty good for a 5500lb daily driver, and good fuel mileage, A very streetable 13.9's on motor, no stall, the 410 gear made a huge diff.. It depends what you want to spend and how streetable you want it to be.. A good tune for it would make it run better than installing that cam..
hucklelberry for what, I've got a little 91 AWD talon turbo, cams clipped & ported, 28psi w/450 hp that we can play with if you like Mr huckleberry.. You can't hook that up.. I see your in Dallas, we need to hook-up and play, And lets see what that s10 can do w/my talon..
