ls1 cam in 5.3
Old 09-20-2010, 02:12 PM
  #31
wheeliE-maxx's Avatar
Originally Posted by RandomHero
Then I guess my question is, why would you put a cam in but not a converter?
Also, why would you think it would run like ****? I daily drive a 3600 converter in a lifted truck and have zero issues. If you ran a tt3000, you wouldn't even remember it was there most of the time.
You can swap a converter or a cam in about the same amount of time.
Do what you will man. It doesn't sound like you're looking for advice, it sounds like you've already made up your mind. Do what you will, but unless you already have the tools and have done at least a handful of cam swaps, I wouldn't bother with an ls1 cam.
I meant that a 224 or whatever size cam wouldn't run to it's potential without a stall, but a 200/210 gm cam would be okay. I'm not sure what my plan is yet. And installing a cam I already have available is cheap but for the most part a converter isn't. I might do a tb stall eventually though
Old 09-20-2010, 02:56 PM
  #32
Wearin' da big hat
00ChevyScott's Avatar
Originally Posted by Big Red Rod
Get that Honda out and put some money on it, And I'll show you a streetable 11 sec. 91 AWD 2.0 DOHC Turbo Talon..
**** the Honda is an 11 sec ride too..
Old 09-20-2010, 09:34 PM
  #33
Torquerolljoe's Avatar
I just picked up a nearly free TB converter. It is new in the box (GM Reman) that I will give a try. The price was right and way less than a Yank, Circle D, etc. If I don't like it, I'll put in a Circle D. Let you guys know how I like it once I get it installed. Also looking at a mild cam from LEP- LS Truck Cam specs 216/220, 561/564 lift. I think with the TB stall, should be perfect...at least I hope!!
Denali08
08-09-2015 04:34 PM
JordanH
08-08-2015 07:59 PM
vmaxpro
08-04-2015 07:02 AM
steves86ta
07-28-2015 10:21 AM
06 4.8
07-15-2015 07:17 PM
Quick Reply: ls1 cam in 5.3
